Siebel Business Process Framework: Workflow Guide > Developing Workflow Processes > Process of Planning Workflow ProcessesThis process is a step in Roadmap for Developing Workflow Processes. To plan a workflow process, do the following tasks:
If your work in Process of Analyzing Business Requirements determined that the workflow process is the most appropriate solution, then you can continue planning the workflow process. When planning a workflow process you determine how to build the workflow process, including making design decisions, such as which workflow mode to use, the events to define, the rules to define, actions that the workflow process runs, and so on. |
| Siebel Business Process Framework: Workflow Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
