Siebel Business Process Framework: Workflow Guide > Developing Workflow Processes > Process of Analyzing Business Requirements >
Identifying an Automation Solution
This task is a step in Process of Analyzing Business Requirements.
After you determine business process requirements and the actions that must be performed to meet those requirements, you can identify an automation solution.
To identify an automation solution
  1. Identify the solution that most closely meets the business process requirements.
    For more information, see Identifying the Solution That Most Closely Meets the Requirements.
  2. Determine if a workflow process or a workflow policy can meet the requirement.
    For more information, see Determining if a Workflow Process or Workflow Policy Meets the Requirement.
Table 5 compares a workflow process to other Siebel automation solutions.
Table 5. Comparison of a Workflow Process to Other Siebel Automation Solutions
Solution
Advantages
Limitations
Workflow Process
This solution includes the following advantages:
  • Visual representation of business logic is simple to understand and maintain
  • Remote synchronous and asynchronous capability provides compatibility across Siebel CRM for scalability and long-running transactions
This solution includes the following limitations:
  • The semantics for control are not as rich as with scripting
  • Limited control of flow for iteration through record sets
  • Limited direct access to object methods
Workflow Policy
  • Replies to a database event regardless of whether or not an Object Manager server component starts the policy
  • Can realize higher transaction throughput for a simple transaction
  • Policy changes might require database downtime
  • More difficult to define than other alternatives
  • Provides only a limited range of actions
Siebel Script
  • Familiar to many developers
  • Provides a set of semantics
  • Is flexible
  • More difficult to maintain and upgrade
  • Slower performance
Table 6 summarizes common requirements and recommends to use a workflow process or a workflow policy. For more information, see Defining Custom Workflow Policies.
Table 6. Determining if a Workflow Process or a Workflow Policy Can Meet the Requirement
Requirement
Possible Solution
Capture business layer logic.
Use a workflow process. Workflow Process Manager and run-time events capture business layer logic.
Use features that a workflow process supports but that workflow policy does not support.
Use a workflow process. A workflow process can provide pause, stop, and error handling capabilities.
Implement complex comparison logic or flow management.
Use a workflow process. A workflow process is recommended to develop and deploy, and to perform complex comparison logic and flow management. For example, through IF, THEN, ELSE, or CASE.
Call a business service.
Use a workflow process. A workflow process can call a business service.
Use a repeating component request.
Use a workflow process. You can set up a workflow process from a repeating server component request but not from a workflow policy.
Repetitive, manual processing.
Use a workflow process. A workflow process is recommended for repetition, timeliness, and for cross functional routing through a business process.
Process an event in a timely fashion.
Perform escalations and notifications.
Capture data layer logic.
Use a workflow policy. Workflow Policy Manager captures data layer logic. Data coming into Siebel CRM in the data layer is not captured in the business layer. This requirement typically indicates a potential candidate for a workflow policy. Example data coming into Siebel CRM in the data layer includes data coming through EIM or MQ channels.
Use features that a workflow policy supports but that a workflow process does not support.
Use a workflow policy. A workflow policy can support some features that are not available or that are difficult to support with a workflow process. For example, email consolidation, duration, and quantity.
Do bulk data uploads.
Use a workflow policy. Workflow Policy Manager is recommended if bulk data upload occurs through EIM.
Do data quality cleaning in the data layer.
Use a workflow policy. Workflow Policy Manager is recommended for working in the data layer.
Siebel Business Process Framework: Workflow Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
