Siebel Business Process Framework: Workflow Guide > Manipulating Data in a Workflow Process >
Accessing Data from a Run-Time Event in a Workflow Process
This topic explains how to configure Siebel CRM to access run-time event data from a workflow process. To access data from a run-time event in a workflow process
- If necessary, display the WF Step Branch object type in the Object Explorer.
For more information, see Displaying Object Types You Use to Develop a Workflow Process.
- In the WF Step Branch list, define the properties for a WF Step Branch using values described in the following table.
Name |
Enter a name for the branch. |
Type |
Condition |
Event Object Type |
Applet |
Event |
InvokeMethod |
Event Object |
Choose the name of the event object that starts the workflow process. |
Sub Event |
NewRecord |
Comments |
Optional |
Event Cancel Flag |
The default is blank. |
- Set up process properties in the Process Designer.
For information, see Using Process Properties.
- Click the first step in the workflow process, and then add a new output argument for each process property that Siebel CRM must populate that references the run-time event.
To add a new output argument, you enter values in the fields that Siebel Tools displays in the Output Arguments tab in the Multi-Value Property Window. Use the example values described in the following table.
Property Name |
Enter a name for the property. |
Type |
Expression |
Value |
GetProfileAttr("RestrucOut") When you define the Profile Attribute field, note the name you give to each of the property values for the Profile Attributes. You use these in Step 9. |
Output Argument |
Leave default value. |
Business Component Name |
Business Component Field |
Comments |
Optional |
- Activate the workflow process.
For more information, see Process of Deploying a Workflow Process.
- Load the run-time events:
- Navigate to the Administration-Runtime Events screen, and then the Events view.
- On the Events list, click Menu, and then click Reload Runtime Events.
- Query the Event field for the run-time event you defined in Step 4.
- Drill down on the Action Set Name field.
- Add a new Action for each process property that the run-time event updates.
For example, to set the ACU Transaction ID and name it Set ACU Trans ID, you can create a new action. You must do the following work for each new action:
- From the applet menu, choose Reload Runtime Events.
