Siebel Business Process Framework: Task UI Guide > Developing a Task UI > Developing a Task UI That Uses Transient Data >
Transferring Data with a Transient Business Component
Siebel CRM transfers data between business components in the same way regardless of whether or not a transient business component is involved. You can configure Siebel CRM to transfer data between a transient business component or a nontransient business component.
To transfer data from a transient business component to a task property
  1. Open the Task Editor.
    For more information, Opening the Task Editor.
  2. In the Task Editor, choose the step that displays after the assignment occurs.
    This step is typically a task view step that allows the user to modify the data of a transient business component.
  3. In the Multi Value Property Window, click the Output Arguments tab.
  4. Assign a field of the transient business component to a task property.
  5. For the assignment type, use Business Component.
To transfer data between a transient business component and another business component
  2. Add a Siebel operation step using values from the following table.
    Property
    Value
    Operation
    Update
  3. Create an output argument:
    1. Choose the Siebel operation step you added in Step 2.
    2. In the Multi Value Property Window, click the Output Arguments tab.
    3. Right-click in the list area of the Multi Value Property Window, and then choose New Record.
    4. Define the new output argument using values from the following table.
      Property
      Description
      Property Name
      Choose the property that contains the data you must transfer.
      Type
      Choose Business Component.
      Business Component
      Choose the business component that receives the data you are transferring.
      Business Component Field
      Choose the business component field that receives the data you are transferring.
      This step updates the target business component.
Siebel Business Process Framework: Task UI Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
