Configuring Siebel Business Applications > Reference Materials for Configuring Siebel Business Applications > Properties of Object Types >
Properties of an Index Column
Table 88 describes some of the properties that Siebel CRM commonly uses with an index column.
Table 88. Properties That Siebel CRM Commonly Uses with an Index Column
Column Name |
Stores the name of the column where the parent index does an operation, such as a sort operation. |
Sequence |
An integer value that stores the order of the column in the index relative to other columns. You must define the Sequence property even if only one index column is defined for an index. |
Sort Order |
Stores the sort order of the index column. The order is one of the following:
- Asc (ascending)
- Desc (descending)
