Table 89. Properties That Siebel CRM Commonly Uses with a Business Component
Class |
The C++ class that defines the functionality of the business component. For more information, see Class Property of a Business Component. |
Name |
A name that must be unique among all business components that reside in the SRF. Siebel CRM uses the name to reference a business component. |
No Delete No Insert No Update |
If set to TRUE, then the user cannot perform the defined data manipulation operation. For example, if No Delete is TRUE, then the user cannot delete a record that is associated with this business component. The default value is FALSE. |
Search Specification |
A conditional expression that Siebel CRM uses to restrict the records that it gets. Defining the search specification on a business component is very similar to defining the search specification on an applet. For more information, see Options to Filter Data That Siebel CRM Displays in an Applet. |
Sort Specification |
A sort specification that Siebel CRM uses to order the records returned. For more information, see Determining How a Business Component Sorts Records. |
Table |
The name of the SQL table where Siebel CRM gets the records that it uses to update most fields in the business component. |
