| Siebel CRM Configuring Siebel Open UI Siebel Innovation Pack 2015 E52417-01 |
![]() Previous |
![]() Next |
View PDF |
Note: Siebel Innovation Pack 2014 is a continuation of the Siebel 8.1/8.2 release. |
Table 1-2 lists the changes in this revision of the documentation to support this release of the software.
Table 1-2 What's New in Configuring Siebel Open UI, Siebel Innovation Pack 2014
| Topic | Description |
"Overview of the Siebel Open UI Development Architecture" |
Modified topic. Includes updated information about the architecture, including plug-in wrappers, event helper objects, and the template manager. |
"Life Cycle of a Plug-in Wrapper" |
New topic. Describes the life cycle of a plug-in wrapper. |
"Customizing the Physical Renderer to Render the Carousel" |
Modified topic. Describes how to customize the physical renderer to render carousel. |
"Customizing the Physical Renderer to Bind Events" |
Modified topic. Describes how to customize the physical renderer to bind events. |
"Customizing the Physical Renderer to Refresh the Carousel" |
Modified topic. Describes how to customize the physical renderer to refresh the carousel. |
"Modifying CSS Files to Support the Physical Renderer" |
Modified topic. Includes new information about adding files that the physical renderer requires. |
"Configuring the Manifest for the Recycle Bin Example" |
Modified topic. Includes new information about adding files that the manifest must specify. |
"Configuring the Manifest for the Color Box Example" |
New topic. Describes how to configure the manifest for the color box example. |
"Guidelines for Customizing Plug-in Wrappers" |
New topic. Outlines guidelines for customizing plug-in wrappers. |
"Deriving Presentation Models, Physical Renderers and Plug-in Wrappers" |
New topic. Describes how to create a reference between two presentation models, where Siebel Open UI derives one presentation model from another presentation model. |
"Customizing How Siebel Open UI Displays Error Messages" |
New topic. You can customize Siebel Open UI to display error messages in a status bar or dialog box. |
"Customizing Navigation Options" |
New topic. It describes how to configure the navigation options available to users. |
Modified topic. Includes several new topics that describe how to customize the way Siebel Open UI handles events. |
"Attaching and Validating Event Handlers in Any Sequence" |
New topic. Describes how to customize the sequence that Siebel Open UI uses when it validates event handlers. |
"Allowing Blocked Methods for HTTP GET Access" |
New topic. Describes how to allow blocked methods for HTTP GET access. |
"Using Temporary Manifest Expressions During Development" |
New topic. Describes how to configure a temporary expression so that you can test and troubleshoot the manifest configuration during development. |
"Customizing List Applets to Render as Carousels" |
Modified topics. You no longer use the theme.js file, mobiletheme.js file, or the tablettheme.js file to customize a theme. You now use the manifest. |
"Using Cascading Style Sheets to Modify the Position, Dimension, and Text Attributes of an Object" |
Modified topic. Describes how to modify the position, dimension and text attributes of an object. |
"Adding Fonts to Siebel Open UI" |
New topic. Describes how to configure Siebel Open UI so that it can use fonts that do not come predefined. |
"Expanding and Collapsing Applets" |
New topic. Describes how to configure Siebel Open UI so that it allows the user to choose more than one row in a list applet. |
"Customizing List Applets to Render as Maps" |
New topic. Describes how to customize list applets to render as maps. |
"Customizing Applets to Capture Signatures from Desktop Applications" |
Modified topic. Includes modifications to the instructions and updated property values. |
"Customizing Applets to Capture Signatures for Siebel Mobile Applications" |
New topic. Describes how to customize applets to capture signatures for Siebel Mobile applications. |
"Enabling Salutation Applets in Siebel Open UI" |
New topic. Describes how to enable the salutation applet so Siebel Open UI can display it in the client. |
"Creating and Managing Client-Side Controls" |
New topic. Includes an example that describes how to customize a text box control that Siebel Open UI displays in the client without modifying the Siebel Server. |
"Configuring Client-Side Multi-Select" |
New topic. Describes how to configure client-side multi-select check-boxes for touch devices. |
"Displaying Control Labels in Different Languages" |
New topic. Describes how to configure Siebel Open UI so that it displays the text for a control label according to the language that the client browser uses. |
"Allowing Users to Drag Items from List Applets to Create Calendar Events" |
New topic. Describes how allow the user to drag an item from a list applet, and then drop it on a calendar to create an event. |
"Customizing How Users View Calendar Availability" |
New topic. Describes how to enable and disable viewing free busy availability in the calendar. |
"Customizing the Calendar All Day Slot" |
New topic. Describes how to show and hide the calendar all day slot. |
"Customizing Participant Availability in Resource Schedulers" |
New topic. Describes how to customize the controls that Siebel Open UI uses to display information about participant availability in a resource scheduler. |
"Displaying Siebel Portlets In External Applications" |
Modified topic. To display a Siebel portlet in an external application, you add parameters to the Application Object Manager. You do not add them to the Siebel Server. |
"About Siebel Mobile Application Logging" |
New topic. Includes information about logging on Siebel Mobile applications. |
"Configuring Interactive Detailing in the Siebel Open UI Application for Siebel Pharma" |
New topic. Describes how to configure the Detail button to appear on an applet in the Siebel Open UI application for Siebel Pharma. |
"Using Siebel Business Services or JavaScript Services to Customize Siebel CRM Objects" |
Modified topic. It describes how to configure Siebel Open UI to anonymously register existing applet and business component objects. |
"Using Custom Siebel Business Services" |
Modified topic. It describes how to customize Siebel business services to make a call to a standalone service using the InvokeMethod method. |
New topic. The AddValidator method validates an event. It allows you to write a custom validation for any event. |
Modified topic. Includes new information about the values that the AttachEventHandler method returns. |
New topic. Describes the Plug-in Wrapper class. |
New topic. Describes the Plugin Builder class. |
New topic. Describes the Template Manager class. |
New topic. Describes the Event Helper class. |
New appendix. Describes post-upgrade configuration tasks. |
