Siebel Financial Services Connector for ACORD P&C and Surety Guide > Configuration Roadmap > Configuring the Connector Components >
FINS ACORD XML Transaction Manager
Several prebuilt operations have been defined in the transaction manager. These operations are sufficient to support most needs in Oracle's Siebel Connector for ACORD XML. It is recommended that you not change these values unless you want to add new operations.
Table 24. User Properties for the FINS ACORD XML Transaction Manager
Operation Name
Value
SAQuery
EAI Siebel Adapter/Query/
SARowIdQuery
EAI Siebel Adapter/Query/PrimaryRowId;!SiebelMessage;
SASynchronize
EAI Siebel Adapter/Synchronize/
SAUpsert
EAI Siebel Adapter/Upsert/
SAUpsert_ROLL_BACK
EAI Siebel Adapter/Delete/RollbackOnSame;
SAOperation_FIND
FINS Industry BC Facility- Service/HierarchySearchSpec/!SiebelMessage;IntObjectName=>SiebelFINSRespIntObjName;
The following are examples of how the values in Table 24 are interpreted:
  • SAQuery means the operation will execute the EAI Siebel Adapter's Query method.
  • SAUpsert means the operation will execute the EAI Siebel Adapter's Upsert method.
The basic format for the value entry is as follows:
  • Service/Method/Argument;Argument;
  • /Method/Argument;Argument;
  • Service, method, and argument are separated by a slash (/).
  • Each argument ends with a semicolon (;).
  • The default Service name is EAI Siebel Adapter.
  • The default argument name is SiebelMessage.
Siebel Financial Services Connector for ACORD P&C and Surety Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
