Siebel Financial Services Connector for ACORD P&C and Surety Guide > Configuration Roadmap > Configuring the Connector ComponentsSiebel Connector for ACORD XML provides four prebuilt business services that you can configure for your specific use:
Each business service has its own user properties. The values of these user properties are decided by configuration time. However, you can also override those values in the workflow by entering a run-time value. The meanings of the user properties are described in Siebel Connector for ACORD XML. This section shows the configuration of the user properties for each of these business services. |
Siebel Financial Services Connector for ACORD P&C and Surety Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
