Siebel Financial Services Connector for ACORD P&C and Surety Guide > Configuration Roadmap > Creating Integration Objects in Siebel Tools >
Compiling the Integration Objects
After you create the integration objects, you compile them into the repository file for use by the connector.
To compile the integration objects
  1. From Siebel Tools, choose Tools > Compile Projects.
    The Object Compiler dialog box appears.
  2. Choose the project, browse to the repository file for the project, or create a new one, and then click Compile.
Siebel Financial Services Connector for ACORD P&C and Surety Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
