Siebel Financial Services Connector for IAA-XML Guide > Troubleshooting > Integration Object Setup Issues > Out-of-Sync DatabaseProblemAfter compiling your .srf file and moving it to your test environment you can not locate your integration objects or DTE maps. SolutionMove your integration objects and DTE maps from your development database to your test database. |
| Siebel Financial Services Connector for IAA-XML Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
