Siebel Financial Services Connector for IAA-XML Guide > Troubleshooting > Integration Object Setup Issues > Setup the Integration Object User Property and Literal ValuesProblemFINS IAA-XML Converter generates XML string without some required fields. SolutionInitialize all required fields in the integration component "XML Literal Value" column. Some values are specified in the integration object/component/component field user property, be sure to customize them to suit your integration need. |
| Siebel Financial Services Connector for IAA-XML Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
