Siebel Financial Services Connector for IAA-XML Guide > Configuration Roadmap > Configuring the IAA-XML Business Service >
FINS IAA-XML Data Transformation Engine
You can configure this business service using the IgnoreEmptyTag integration map argument. You can access this argument when configuring the data transformation maps in the Data Maps screen. When this argument is available, the FINS IAA-XML Data Transformation Engine can remove the empty-value integration component fields in the integration object received.
Siebel Financial Services Connector for IAA-XML Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
