Siebel Financial Services Connector for IAA-XML Guide > Configuration Roadmap > Configuring the IAA-XML Business Service > FINS IAA-XML ConverterTable 26 displays the only user property you can configure for this business service. This value will appear in the pre-header section of your IAA-XML message.
Besides, the FINS IAA-XML converter uses the IAA-XML hierarchy represented in the external integration object to guide the message through the converting process. If there are elements in the external integration object instance received that do not have a definition defined in the integration object definition, the converter errors out. If you expect such a situation, you can set the Ignore Undefined XML Tag parameter on the user property of the corresponding integration object. NOTE: This user property is created by wizard and is set to Y. You can turn it off if you wish the converter to error out. |
Siebel Financial Services Connector for IAA-XML Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
