Siebel Financial Services Connector for IAA-XML Guide > Configuration Roadmap > Configuring Server TasksA server task is an instantiation of a server component. To run a server task, you need to run a component request, which will request for one or more server task to run. The server task you need to run for your Siebel Connector for IAA-XML is Siebel EAI MQSeries Server Transport. The Siebel EAI MQSeries Server Transport is designed to provide a messaging solution to help you integrate data between Siebel Business Applications and external applications that can interface with the IBM MQSeries. The EAI MQSeries Server Transport transports messages to and from IBM MQSeries queues. In order to run this server task successfully you need to first configure two named subsystems.
After creating and configuring your Named Subsystem you need to configure the MQSeries Receiver. To configure MQSeries Receiver parameters
NOTE: For details on creating and configuring server tasks, see Siebel System Administration Guide and for details on configuring MQSeries, see Transports and Interfaces: Siebel Enterprise Application Integration. |
| Siebel Financial Services Connector for IAA-XML Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
