Siebel Financial Services Connector for IAA-XML Guide > Configuration Roadmap > Creating Integration Objects in Siebel ToolsIn order to use the Siebel Connector for IAA-XML you need to build three different types of integration objects: IAA Envelope Integration Object. For details, see To Create Integration Object. IAA External Integration Objects. For details, see To create IAA external integration objects. IAA Internal Integration Objects. For details, see Creating IAA Internal Integration Objects. You use the Integration Object Builder in Siebel Tools to create these integration objects. The Builder first walks you through steps for selecting your project, business service, and .DTD file and then provides you with the option of creating all three types of integration objects or just the ones you need. NOTE: All the integration objects used in the following procedures are included in the Sample database.
| Siebel Financial Services Connector for IAA-XML Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
