Integration Platform Technologies: Siebel Enterprise Application Integration > Creating and Maintaining Integration Objects > About Synchronizing Integration Objects > Synchronization RulesDuring the synchronization process, the wizard follows particular update rules. Consider a simple example involving the Siebel Account integration object with only Contact and its child components marked as active in the object. Figure 19 helps you to visualize this example. Because the Account component is the parent of Contact, it is also selected, even though you cannot see it in Figure 19. |
Integration Platform Technologies: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
