Integration Platform Technologies: Siebel Enterprise Application Integration > Creating and Maintaining Integration Objects > About Synchronizing Integration Objects > Updating the Entire Integration ObjectEither the business object or the integration object might have changed since the integration object was first created. The Synchronization wizard creates a new object that takes into account any business object and integration object changes. Figure 20 illustrates how the Synchronization wizard takes into account any changes. Figure 21 shows how the resulting integration object is structured after the synchronization. The integration object now contains two new components, Business Address and Opportunity. Other components are updated with the definitions of the corresponding components in the business object. |
| Integration Platform Technologies: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
