Integration Platform Technologies: Siebel Enterprise Application Integration > EAI UI Data Adapter Business Service > EAI UI Data Adapter Business Service Methods > DeleteLeaves MethodThe DeleteLeaves method deletes leaf nodes only. If the Cascade Delete on the Link object is set to TRUE, then child records are also deleted. Row Ids are required for both internal nodes and leaf nodes. DeleteLeaves does not return a value when the operation is successful. Method Arguments for DeleteLeavesTable 34 lists the method arguments used with DeleteLeaves. For descriptions of the arguments, see EAI UI Data Adapter Business Service Method Arguments.
Example of Deleting a Root ComponentThis example demonstrates deleting a root component. <SiebelMessage MessageType="Integration Object" IntObjectName="Account" IntObjectFormat="Siebel Hierarchical"> Example of Deleting a Child ComponentThis example demonstrates deleting a child component. <SiebelMessage MessageType="Integration Object" IntObjectName="Account" IntObjectFormat="Siebel Hierarchical"> |
| Integration Platform Technologies: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
