Integration Platform Technologies: Siebel Enterprise Application Integration > Siebel Virtual Business Components > XML Gateway Service >
XML Gateway Method Arguments
The XML Gateway init, delete, insert, preInsert, query, and update methods take the arguments presented in Table 41.
Table 41. XML Gateway Arguments
Argument
Description
Remote Source
The VBC Remote Source user property. The remote source from which the service is to retrieve data for the business component. This must be a valid connect string. When configuring the repository business component on top of the specialized business component class CSSBCVExten, you can define a user property Remote Source to allow the Transport Services to determine the remote destination and any connect information. If this user property is defined, then it is passed to every request as the remote-source tag.
Business Component Id
Unique key for the given business component.
Business Component Name
Name of the business component or its equivalent, such as a table name.
Parameters
The VBC Service Parameters user property. A set of string parameters required for initializing the XML Gateway.
Integration Platform Technologies: Siebel Enterprise Application Integration Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
