Integration Platform Technologies: Siebel Enterprise Application Integration > Siebel Virtual Business Components > XML Gateway ServiceThe XML Gateway business service communicates between Siebel Business Applications and external data sources using XML as the data format. For information on XML format, see Examples of the Outgoing XML Format and Examples of the Incoming XML Format. The XML Gateway business service can be configured to use one of the following transports: You can configure the XML Gateway by specifying the transport protocol and the transport parameters you use in the Service Parameters User Property of the VBC, as shown in Table 39. When using the XML Gateway, specify the following user properties for your VBC. NOTE: You can concatenate multiple name-value pairs using a semicolon (;), but do not use any spaces between the name, the equal sign, the value, and the semicolon. For example, if you want to specify the EAI HTTP Transport, then you can use something like the following: "Transport=EAI HTTP Transport;HTTPRequestURLTemplate=<your URL>;HTTPRequestMethod=POST" You can also implement a VBC with MQSeries. The following procedure lists the steps you take to implement this. To implement a VBC with MQSeries
| Integration Platform Technologies: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
