Transports and Interfaces: Siebel Enterprise Application Integration > EAI JMS Transport > Detailed Input and Output Specifications for the EAI JMS Transport >
Input Arguments Used by the Dispatch Step
Table 12 shows the options for each input argument of the JMS Transport methods, except user-defined properties and arguments used by the Dispatch step. R denotes a required argument; NR denotes an optional argument (not required); and I denotes an argument that is ignored.
Table 12. Dispatch Step Input Arguments
ConnectionFactory |
R |
R |
R |
R |
R |
R |
R |
R |
ReceiveQueue |
I |
I |
R |
R |
I |
R |
R |
I |
ReceiveTimeout |
I |
I |
NR |
NR |
NR |
NR |
NR |
NR |
SendQueue |
R |
I |
R |
I |
I |
I |
R1 |
I |
Topic |
I |
R |
I |
I |
R |
I |
I |
R |
ConnectionUsername* |
NR |
NR |
NR |
NR |
NR |
NR |
NR |
NR |
ConnectionPassword* |
NR |
NR |
NR |
NR |
NR |
NR |
NR |
NR |
SendUsername** |
NR |
I |
NR |
I |
I |
NR |
I |
I |
SendPassword** |
NR |
I |
NR |
I |
I |
NR |
I |
I |
ReceiveUsername** |
I |
I |
NR |
I |
I |
I |
NR |
I |
ReceivePassword** |
I |
I |
NR |
I |
I |
I |
NR |
I |
TopicUsername** |
I |
NR |
I |
I |
NR |
I |
I |
NR |
TopicPassword** |
I |
NR |
I |
I |
NR |
I |
I |
NR |
SubscriberIdentifier |
I |
I |
I |
I |
R |
I |
I |
R |
JMS Headers |
JMSPriority |
NR |
NR |
NR |
I |
I |
I |
NR2 |
I |
JMSDeliveryMode |
NR |
NR |
NR |
I |
I |
I |
NR2 |
I |
JMSExpiration |
NR |
NR |
NR |
I |
I |
I |
NR2 |
I |
JMSReplyTo |
NR |
NR |
I3 |
I |
I |
I |
NR2 |
I |
JMSType+ |
NR |
NR |
NR |
I |
I |
I |
NR2 |
I |
JMSCorrelationID+ |
NR |
NR |
NR |
I |
I |
I |
I4 |
I |
Dispatch |
Connection Subsystem++ |
NR |
NR |
NR |
NR |
NR |
NR |
NR |
NR |
DataHandling Subsystem+++ |
I |
I |
I |
I |
I |
NR |
NR |
NR |
DispatchService |
I |
I |
I |
I |
I |
R5 |
R5 |
R5 |
DispatchMethod |
I |
I |
I |
I |
I |
R5 |
R5 |
R5 |
DispatchWorkflow Process |
I |
I |
I |
I |
I |
R5 |
R5 |
R5 |
DispatchRuleSet |
I |
I |
I |
I |
I |
R5 |
R5 |
R5 |
ConverterService++++ |
I |
I |
I |
I |
I |
NR |
NR |
NR |
Some special notes regarding particular values in Table 12:
In place of providing the arguments individually, the single argument ConnectionSubsystem can be provided. Its value must be the name of a valid named subsystem of type JMSSubsys, and it must include all of the arguments that are required by the method to which it is passed. See About the JMS Receiver for more information about that named subsystem. JMS message properties are also supported as input arguments (properties) as described in JMS Headers and Properties. Input Argument Values
Table 13 provides details for each input argument about the allowable values, default values, and special values, as well as the behavior if an invalid value is passed.
Table 13. Values for Input Arguments
ConnectionFactory |
NONE |
JNDI connection factory name |
Not applicable |
ERROR |
ReceiveQueue |
NONE |
JNDI queue name |
Not applicable |
ERROR |
ReceiveTimeout |
3000 |
Any integer greater than or equal to 0 |
0: Wait indefinitely |
Noninteger defaults to 3000 Integer less than 0 defaults to 0 |
ConnectionUsername |
NONE |
Valid username |
Not applicable |
Not applicable |
ConnectionPassword |
NONE |
Valid password |
Not applicable |
Not applicable |
SendQueue |
NONE |
JNDI queue name |
Not applicable |
ERROR |
SendUsername |
NONE |
Valid username |
Not applicable |
Not applicable |
SendPassword |
NONE |
Valid password |
Not applicable |
Not applicable |
ReceiveUsername |
NONE |
Valid username |
Not applicable |
Not applicable |
ReceivePassword |
NONE |
Valid password |
Not applicable |
Not applicable |
TopicUsername |
NONE |
Valid username |
Not applicable |
Not applicable |
TopicPassword |
NONE |
Valid password |
Not applicable |
Not applicable |
Topic |
NONE |
JNDI topic name |
Not applicable |
ERROR |
NONE |
ANY STRING |
Not applicable |
Not applicable |
JMS Headers |
JMSCorrelationID |
NOT SET |
ANY STRING |
Not applicable |
Not applicable |
JMSPriority |
javax.jms.Message. DEFAULT_PRIORITY (4) |
Any integer from 0 to 9 |
(0 lowest; 9 highest) |
DEFAULT |
JMSDeliveryMode |
javax.jms.Delivery Mode.PERSISTENT |
PERSISTENT, NON_PERSISTENT |
Not applicable |
DEFAULT |
JMSExpiration |
javax.jms.Message. DEFAULT_TIME_TO_ LIVE (0) |
Any nonnegative integer |
0: Message never expires |
DEFAULT |
JMSReplyTo |
NOT SET |
JNDI queue name |
Not applicable |
ERROR |
JMSType |
SiebelJMSMessage |
ANY STRING |
Not applicable |
Not applicable |
Dispatch |
ConnectionSubsystem |
NONE |
A JMSSubsys named subsystem |
Not applicable |
ERROR |
DataHandlingSub system |
NONE |
An EAITransportData HandlingSubsys named subsystem |
Not applicable |
ERROR |
DispatchService |
NONE |
Business service name |
Not applicable |
ERROR |
DispatchMethod |
NONE |
Business service method |
Not applicable |
ERROR |
NONE |
Workflow name |
Not applicable |
ERROR |
DispatchRuleSet |
NONE |
Rule set name |
Not applicable |
ERROR |
ConverterService |
NONE |
Not applicable |
ERROR |
