Business Processes and Rules: Siebel Enterprise Application Integration > Creating and Using Dispatch Rules > EAI Dispatch Service Scenarios > Outbound Scenarios Using ProcessAggregateRequestThe ProcessAggregateRequest method allows you to have multiple invocation of one or more methods in one or more business services using a single request. The following examples illustrate the use of this method to query account and employee information. Querying the Account Integration ObjectThe following example shows how you can invoke multiple business services and setting arguments for each of the services. This is done using simple arguments for the services and by having the aggregate request invoke the QueryPage method of the EAI Siebel Adapter twice, with different searchspecs. <?xml version="1.0" encoding="UTF-8"?> Querying the Employee Integration ObjectThe following example shows how you can set complex type business service method arguments. The aggregate request invokes the EAI Siebel Adapter twice, and, instead of using searchspec, uses query by example by passing in a SiebelMessage. NOTE: All simple arguments are attributes of the ArgumentWrapper element, and the complex argument is a child element. <?xml version="1.0" encoding="UTF-8" ?> |
| Business Processes and Rules: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
