Business Processes and Rules: Siebel Enterprise Application Integration > Creating and Using Dispatch Rules >
Examples of Search Expression Grammar
In the following example, assume that the XML document is a typical document your system receives and that you want to set some rules for the EAI Dispatch Service to use to parse this document. <?xml version="1.0" encoding="UTF-8" ?>
- <cXML payloadID="3223232@ariba.acme.com" timestamp="1999-03-12T18:39:09-08:00" xml:lang="en-US">
- <Header> - <From> - <Credential domain="AribaNetworkUserId"> <Identity>admin@acme.com</Identity> </Credential> - <Credential domain="AribaNetworkUserId" type="marketplace"> <Identity>bigadmin@marketplace.org</Identity> </Credential> - <Credential domain="BT"> <Identity>2323</Identity> </Credential> </From> - <To> - <Credential domain="DUNS"> <Identity>942888711</Identity> </Credential> </To> - <Sender> - <Credential domain="AribaNetworkUserId"> <Identity>admin@acme.com</Identity> <SharedSecret>abracadabra</SharedSecret> </Credential> <UserAgent>Ariba.com Network V1.0</UserAgent> </Sender> </Header> - <Request deploymentMode="test"> -<OrderRequest> - <OrderRequestHeader orderID="DO1234" orderDate="1999-03-12" type="new"> - <Total> <Money currency="USD">12.34</Money> </Total> - <ShipTo> ....... .......
Table 5 provides some valid search expression examples.
Table 5. Dispatch Rule Grammar
/*/Header |
Go to the second level and look at the type value of each property set and check whether it is of value Header. |
/*/*@DeploymentMode |
Go to the second level and look at the properties of each property set and check whether any of them has the name (not the value) of DeploymentMode. |
/*/*/Request@DeploymentMode |
Go to the third level and look at each property set for type of value Request and property of name DeploymentMode. |
/cXML/*/OrderRequest |
Search at the top level for type of value cXML and then upon matching, find a grandchild (not child) of type of value OrderRequest. |
Following are examples of invalid rules: Rule
/*/*@DeploymentMode/Request/SiebelMessage
Description
This is not a valid rule. A search for a property value must be specified at the very end. A correct form would be the following, which will have a different result. /*/Request/*@DeploymentMode
Rule
/*@PayLoadID@TimeStamp
Description
This also is not a valid rule. It is not possible to specify more than one property name. The correct form would use two different rules to represent this: /*@PayLoadID
and /*@TimeStamp
