Business Processes and Rules: Siebel Enterprise Application Integration > Data Mapping Using the Siebel Data Mapper > The Siebel Data MapperThe Siebel Data Mapper maps one integration object, source, to another integration object, target. Integration objects contain one or more integration components, which in turn contain one or more integration fields. For details on integration objects, see Integration Platform Technologies: Siebel Enterprise Application Integration. Figure 9 illustrates the Siebel Data Mapping Engine architecture. A data map defines the relationship between source and target object format. The map controls the transformation process. Transformation maps are stored in the Siebel Database as explained in Table 10. |
| Business Processes and Rules: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
