Business Processes and Rules: Siebel Enterprise Application Integration > Data Mapping Using Scripts > Siebel Message Objects and Methods > CSSEAIIntMsgOutThis object represents an output integration message that is open for writing. The object provides CreateIntObj and SetArgument methods: CreateIntObj() MethodThis method creates a new integration object. Table 17 presents the parameter for this method. Syntax
ReturnsCSSEAIIntObjOut Output Integration Object UsageAn integration message can contain only one integration object, so multiple calls to this method on one integration message raises an error. The name must agree with the business service argument OutputIntObjName, if that argument is passed to the service. SetArgument() MethodThis method sets the value of a business service argument. Table 18 presents the parameters for this method. Syntax
ReturnsUsageYou can call the SetArgument method to establish the value of a given output argument for the business service method invocation. SetAttachmentSource() MethodThis method establishes the source object to copy attachment objects from. The source object must be a CSSEAIIntMsgIn, CSSEAIMimeMsgIn, or other object implementing the GetAttachmentByCID method. Table 19 presents the parameter for this method. SyntaxCopyAttachment() MethodThis method copies an attachment from the attachment source to the output integration object. The attachment is referenced by the MIME Content Identifier (CID). The attachment source must be established by calling CSSEAIIntMsgOut.SetAttachmentSource before calling this method. Table 20 presents the parameter for this method. SyntaxReturnsThe attachment copy is returned as a property set. This method returns null if the attachment source does not contain an attachment with the specified CID. |
| Business Processes and Rules: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
