Business Processes and Rules: Siebel Enterprise Application Integration > Data Mapping Using Scripts > Siebel Message Objects and Methods > CSSEAIIntObjInThis object represents an input integration object, open for reading, that is contained in the integration message. The integration object has a name and contains zero or more instances of actual integration objects. Integration object instances are accessed one at a time, similar to accessing database records. Each instance has a primary integration component that contains data and every subordinate integration components. This object provides the Exists, FirstInstance, GetPrimaryIntComp, and NextInstance methods. Exists() Method23This method checks to see if the integration object is actually present in the input data. It takes no parameters. SyntaxReturnsUsageCall Exists after retrieving the integration object from the integration message. If the integration object was found and is open for reading, the Exists method returns true. FirstInstance() MethodThis method moves to the first integration object instance and sets it as the active instance. SyntaxReturnsUsageThe FirstInstance method returns true if the instance exists, false otherwise. GetPrimaryIntComp() MethodThis method returns the primary integration component of the active instance of the integration object. Table 21 presents the parameter for this method. Syntax
ReturnsCSSEAIPrimaryIntCompIn Input Primary Integration Component UsageGets the primary integration component of the active instance of the integration object and opens it for input. This method always returns an input primary integration component object, even if the component does not exist. Call the Exists method on the returned object to test for this condition. If there is no active instance, a call to this method raises an error. NextInstance() MethodThis method moves a pointer to the next logical integration object instance in the active integration message. SyntaxReturnsUsageMoves to the next integration object instance and makes it the active instance. This method returns true if the instance exists, or false if there are no more instances. If neither the NextInstance or the FirstInstance method has been called previously, the NextInstance method moves to the first instance in the message. |
| Business Processes and Rules: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
