Business Processes and Rules: Siebel Enterprise Application Integration > Data Mapping Using Scripts > EAI Value Maps > EAIGetValueMap() MethodThis method retrieves objects for the required Type-Direction mapping. Table 55 presents the parameters for this method. SyntaxEAIGetValueMap(type, direction [, unmappedKeyHandler]) ReturnsAn object you can use to access the EAI Value Maps. UsageUse this method at the beginning of a script function to retrieve objects for the required Type-Direction mapping. Then call the object's Translate method to get the translation of a code from the map table as needed within the function. NOTE: Providing a Type-Direction pair that does not have an entry in the EAI Value Map raises an error at the first call to the Translate method. |
| Business Processes and Rules: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
