XML Reference: Siebel Enterprise Application Integration > Siebel XML Converters > XML ConverterThe XML converter uses no integration object metadata. The rules for converting between XML documents and property sets are essentially the same as the XML Hierarchy Converter. This service, however, does not create an XML hierarchy property set, but instead the XML document's root element becomes a Type top-level property set (for example, Service Method Arguments). The service is intended for importing and exporting hierarchical data (arguments, definitions, and so on) and for passing property set arguments to and from business services. NOTE: When using this business service, you do not specify an output argument name. The Siebel application automatically maps the newly generated property set to the specified output process property. Figure 6 shows the translation of an XML document into a property set representation within Siebel XML, and back again. The following topics are also described here:
XML Converter Business Service MethodsUse the XML Converter when you want to convert any property set to XML, or convert an XML document that is not a Siebel EAI Integration Object Message to a property set. There are two methods for the XML Hierarchy Converter, as shown in Table 31. The arguments for each method appear in Table 32, Table 33, Table 34, and Table 35. Property Set To XML Method ArgumentsTable 32 describes the input argument for the Property Set To XML method of the XML Converter. Table 33 describes the output argument for the Property Set To XML method of the XML Converter. XML To Property Set Method ArgumentsTable 34 describes the input argument for the XML To Property Set method of the XML Converter. Table 35 describes the output argument for the XML To Property Set method of the XML Converter.
| XML Reference: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
