XML Reference: Siebel Enterprise Application Integration > Siebel XML Converters >
Siebel XML Converter Business Service Comparison
Table 36 shows the basic differences between the four XML Converter business services. The table also gives guidelines on the appropriate usage. The following terminology is used in Table 36:
  • Yes. Supported by the converter.
  • Yes-second. Supported when used with a second converter.
    NOTE:  The EAI Integration Object to XML Hierarchy Converter always requires the XML Hierarchy Converter in the following instances.
  • No. Not supported by the converter.
Table 36. Siebel XML Converter Comparison
Support or Requirement
EAI
XML
Converter
XML Converter
Siebel Workflow
Yes
Yes
Yes-second
No
Siebel Data Mapper
Yes
Yes-second
(with the EAI Integration Object Hierarchy Converter)
Yes-second
No
Siebel eScript for data transformation
Yes
Yes
Yes-second
No
Custom XML envelopes
No
Yes
Yes-second
No
Dispatch Service
Yes
Yes
Yes-second
No
XML representing business service method arguments
No
No
Yes-second
Yes
Serializing property sets as XML
No
No
Yes-second
Yes
Internal representation
Siebel Message (integration object instance)
XML Hierarchy
Property Set
Requirement for creating an integration object definition
Yes
No
Yes
No
XML Reference: Siebel Enterprise Application Integration Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
