XML Reference: Siebel Enterprise Application Integration > Scenarios for Siebel EAI XML Integration > Scenario 1: Process of Inbound Integration Using Siebel XMLThis topic gives an example of how to set up an inbound integration using XML. You might use the integration differently, depending on your business model. To set up the inbound integration, perform the following tasks: Creating the XML SchemaUse the Generate Schema wizard in Siebel Tools to create an XSD or a DTD for the incoming XML. For details on using the Siebel XSD Wizard, see XML Integration Objects and the XSD Wizard. For details on using the Siebel DTD Wizard, see XML Integration Objects and the DTD Wizard. To create the XML schema: XSD, DTD, or XDR
Creating the WorkflowCreate a new workflow using the Workflow Process Designer. For details on Siebel Workflow, see Siebel Business Process Framework: Workflow Guide.
Running the IntegrationIn this scenario, assume that either an external application has generated Siebel XML that requires no translation or Siebel XML is XML that conforms to the Siebel XSD or DTD. |
| XML Reference: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
