XML Reference: Siebel Enterprise Application Integration > Scenarios for Siebel EAI XML Integration > Scenario 2: Process of Outbound Integration Using External XML and an XSD or DTDThis topic gives one example of how to set up an integration based on incoming XLML that has been defined in an XSD or a DTD. You might use this integration differently, depending on your business model. To set up the outbound integration, perform the following tasks: Creating the Integration ObjectCreate a new external Siebel integration object. For details on creating integration objects, see Integration Platform Technologies: Siebel Enterprise Application Integration. To create the Siebel integration object
Mapping the DataUse Siebel Data Mapper to map the fields in the external integration object with an internal Siebel integration object. For details on using the Siebel Data Mapper, see Business Processes and Rules: Siebel Enterprise Application Integration.
Running the IntegrationIn this scenario, assume that the external application has generated external XML and includes an associated XSD or a DTD. |
| XML Reference: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
