Siebel Events Management Guide > Registration Business Service Methods > Descriptions of Business Services Methods >
EventRegistrationService Business Service Methods
This topic describes the EventRegistrationService business services methods.
EnrollAdmin Method
This method is used to register one or more individuals. Input Property set is a nested property set where each row is an input contact or prospect. This method is invoked from RegisterAll button, where all dummy records in the current context are registered. See Table 12 for a description of EnrollAdmin Method properties.
NOTE:  Input Properties marked by an asterisk(*) indicate a required field.
Table 12. EnrollAdmin Method Properties
Properties
Description
EventId*
Input Property - Row Id of the Event.
Prospect ID
Input Property - Row Id of the prospect being registered. This property is used by the Siebel Marketing Server during campaign execution.
Type ('EVENT')
Input Property - Always set to "EVENT"
List Id
Input Property - List Id that contains the contact, if applicable.
List Owner Id
Input Property - The list creator Id that contains the contact, if applicable.
Dummy Id (Dummy regn Id)
Input Property - Dummy registration record Id.
Contact Id
Input Property - The row Id of the contact being registered.
User Type*
Input Property - type of individual being registered. "Contact" or "Prospect."
Return Val*
Output Property - "Success" or "Failure."
Output Type*
Output Property - Further information on the result.
Shopping Flag
Output Property - Determines whether the Shopping Cart process is required. "YES" or Null.
Error Regn
Output Property - Cumulative error message with additional information.
EnrollUser Method
This method is used to register a single contact or prospect. See Table 13 for a description of EnrollUser Method properties.
Table 13. EnrollUser Method Properties
Properties
Description
Event Id*
Prospect Id
Type ('EVENT')
Input Property - Always set to "EVENT."
List Id
List Owner Id
Input Property - List creator Id that contains the contact, if applicable.
Registration Date
Input Property - Date of registration.
Contact Id
Input Property - Row Id of the contact being registered.
User Type* (Contact or Prospect)
Input Property - Type of individual being registered. "Contact" or "Prospect."
Return Val* (Success or Failure)
Output Type* (Info on the return value)
Error String
Output Property - Event Id.
Error Message (Error encountered)
Output Property - Description of any error encountered.
Error Param (User Id)
Output Property - Contact or Prospect Id.
Reg Id (Registration Id)
Output Property - Attendee Id.
Error Code (Contains Error Identifier)
Output Property - Siebel Error Id.
Shopping Flag (YES or "")
Output Property - Determines whether the event is fee based and needs to go through the Shopping Cart process. "YES" or Null.
CheckPreviousRegn Method
This method determines if a previous registration or attendee record exists. See Table 14 for a description of CheckPreviousRegn Method properties.
Table 14. CheckPreviousRegn Method Properties
Properties
Description
Event Id*
Prospect Id
Contact Id
Error String (Contains Event Id)
Reg Id (Old regn if it exists)
Regn Status (Status of the old regn)
Output Property - Status of previous attendee record.
CheckSpace Method
This method checks if there is capacity for registration. See Table 15 for a description of CheckSpace Method properties.
Table 15. CheckSpace Method Properties
Properties
Description
Event Id*
Prospect Id
Contact Id
CleanSpace Method
This method removes any old pending registration or attendee records that do not belong to the current user, to free up capacity. The Business Component User Property "Reservation Time Out Hour" determines how long these records exist before being deleted. See Table 16 for a description of CleanSpace Method properties.
Table 16. CleanSpace Method Properties
Properties
Description
Event Id*
Prospect Id
Contact Id
Output Property - "Success" or "Failure"
CreateRegistration Method
This method calls the UpdateSpace method to create a registration and seat counts. Then calls CheckQuote to determine if a quote needs to be created. See Table 17 for a description of CreateRegistration Method properties.
Table 17. CreateRegistration Method Properties
Properties
Description
Event Id*
Prospect Id
Contact Id
List Id
ListOwnerId
DummyId
Quote Item Id
Output Property - Quote Item Row Id.
Reg Id
Shopping Flag ("Y" or "")
UpdateRegistration Method
This method is called when a pending registration or attendee already exists. Completes the registration by calling other methods as necessary. See Table 18 for a description of UpdateRegistration Method properties.
Table 18. UpdateRegistration Method Properties
Properties
Description
Event Id*
Prospect Id
List Id
List Owner Id
Registration Date
Contact Id
Reg Id*
Status*
Input Property - Status of the registration.
Quote Item Id
Reg Id
UpdateSpace Method
This method creates or updates a regn and updates event counts within a Lock to ensure transaction integrity. See Table 19 for a description of UpdateSpace Method properties.
Table 19. UpdateSpace Method Properties
Properties
Description
Event Id*
Prospect Id
Contact Id
Action* (Mode of Operation to be performed - create regn, update regn)
Input Property - Operation can be performed.
Increase count: Enroll an attendee
Drop from enroll: Drop an attendee (no functionality present for this currently)
Drop from waiting: Drop an WL attendee (no functionality present for this currently)
Drop from invited: Drop an invitee (no functionality present for this currently)
Waiting to enroll: Enroll an existing attendee (called from Update Regn)
Invitee to enroll: Enroll an invitee (called from Update Regn)
Reg Id
CheckQuote Method
This method determines whether the current user needs to be charged. See Table 20 for a description of CheckQuote Method properties.
Table 20. CheckQuote Method Properties
Properties
Description
Prospect Id
Contact Id
Reg Id*
Input Property - Registration or attendee row Id.
AddToShoppingCart Method
This method invokes the shopping service to create a quote item. See Table 21 for a description of AddToShoppingCart Method properties.
Table 21. AddToShoppingCart Method Properties
Properties
Description
Prospect Id
Contact Id
Reg Id*
Event Id*
Input Property - Event row Id.
Quote Id
Output Property - Quote Row Id (Returns a quote id if a new quote is created).
Quote Item Id
Output Property - Quote Item Row Id (Returns a quote item Id if the quote item already exists in the same Web session).
Siebel Events Management Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
