Siebel Events Management Guide > Registration Business Service Methods > Descriptions of Business Services Methods >
SessionRegistrationService Business Service Methods
This topic describes the SessionRegistrationService business services methods.
EnrollAdmin Method
This method is used to register one or more individuals. Input property set is a nested property set where each row is an input contact or prospect. This method is invoked from the RegisterAll button, where all dummy records in the current context are registered. See Table 22 for a description of EnrollAdmin Method properties.
NOTE:  Input Properties marked by an asterisk(*) indicate a required field.
Table 22. EnrollAdmin Method Properties
Properties
Description
EventId*
Input Property - Event Row Id.
Session Id
Input Property - Session Row Id.
Prospect Id
Input Property - Row Id of the prospect being registered. This property is used by the Siebel Marketing Server during campaign execution.
Type('SESSION')
Input Property - Always set to "SESSION."
Dummy Id (Dummy regn Id)
Input Property - Dummy registration record Id.
Contact Id
Input Property - Row Id of the contact being registered.
User Type* (Contact or Prospect)
Input Property - Type of individual being registered. "Contact" or "Prospect."
Return Val* (Success or Failure)
Output Property - Further information on the result.
Output Type* (Info on the return value)
Shopping Flag (YES or "")
Output Property - Determines whether the Shopping Cart process is required. "YES" or Null.
Error Regn (A grouped error message if applicable)
Output Property - Cumulative error message with additional information.
EnrollEndUser Method
This method is used for multi-session registration for a contact or a prospect. Check for time overlaps between selected sessions and existing session registrations. Uses a nested property set. See Table 23 for a description of EnrollEndUser Method properties.
Table 23. EnrollEndUser Method Properties
Properties
Description
Event Id*
Session Id
Prospect Id
Input Property - Row Id of the prospect being registered. This property is used by Siebel Marketing Server during campaign executions.
Type ('SESSION')
Contact Id
Reg Id (Empty)
Input Property - Registration or attendee row Id. Not used.
Status (Empty)
Input Property - Registration or attendee status. Not used.
Registration Date (Empty)
Input Property - Registration date. Not used.
Parent Registration Id (Empty)
Input Property - Registration or attendee row Id for the session's parent event. Not used.
Start Date*
Input Property - Start Date and Time of the session.
End Date*
Input Property - End Date and Time of the session.
Name*
Input Property - Name of the session (used for error messaging).
Output Property - "Success" or "Failure."
Shopping Flag ("YES" or "")
Parent Reg Id
Output Property - Registration or attendee row Id for the session's parent event.
CheckOverlaps Method
This method is used to determine if any of the sessions selected for registration within the event have time overlaps or conflict with prior registered sessions for the attendee. Uses a nested property set. See Table 24 for a description of CheckOverlaps Method properties.
Table 24. CheckOverlaps Method Properties
Properties
Description
Event Id*
Session Id
Prospect Id
Type ('SESSION')
Contact Id
Reg Id (Empty)
Status (Empty)
Input Property - Registration date. Note used.
Start Date*
End Date*
Name*
Error String (Contains Session Id)
Output Property - Event Id
Error Message (Error encountered)
Output Property - Description of any error encountered.
Error Param (User Id)
Output Property - Contact or Prospect Id.
Error Code (Contains Error Identifier)
Output Property - Siebel Error Id.
Reg Id
Output Property - Attendee Id.
Shopping Flag ("Y" or "")
EnrollUser Method
This method is used to register a single contact or prospect. See Table 25 for a description of EnrollUser Method properties.
Table 25. EnrollUser Method Properties
Properties
Description
Event Id*
Session Id
Prospect Id
Type ('SESSION')
Status
Reg Id (Empty)
Parent Registration Id*
Input Property - Registration or attendee row Id for the sessions' parent event.
Registration Date
Input Property - Registration date. (Only required if multiple registration records exist for the same contact.)
Contact Id
Error String (Contains Event Id)
Output Property - Event Id.
Reg Id (RegistrationId)
CheckPreviousRegn Method
This method is used to determine if a previous registration or attendee record exists. See Table 26 for a description of CheckPreviousRegn Method properties.
Table 26. CheckPreviousRegn Method Properties
Properties
Description
Session Id*
Prospect Id
Input Property - Row Id of the prospect being registered. This property is used by Siebel Marketing Server during campaign execution.
Contact Id
Reg Id (Old regn if it it exists)
Regn Status (Status of the old regn)
Output Property - Status of previous attendees record.
Parent Reg Id
CheckParentRegn Method
This method determines if the attendee is registered for the session's parent event. See Table 27 for a description of CheckParentRegn Method properties.
Table 27. CheckParentRegn Method Properties
Properties
Description
Session Id*
Prospect Id
Contact Id
Event Id*
Parent Reg Id
Parent Status
Output Property - Status of the session's parent event.
CheckSpace Method
This method checks if there is capacity for registration. See Table 28 for a description of CheckSpace Method properties.
Table 28. CheckSpace Method Properties
Properties
Description
Session Id*
Prospect Id
Contact Id
CleanSpace Method
This method removes any old pending registration or attendee records that do not belong to the current user, to free up capacity. The Business Component User Property "Reservation Time Out Hour" determines how long these records exist before being deleted. See Table 29 for a description of CleanSpace Method properties.
Table 29. CleanSpace Method Properties
Properties
Description
Session Id*
Prospect Id
Contact Id
CreateRegistration Method
This method calls the UpdateSpace method to create a registration and seat count. Then it calls CheckQuote to determine if a quote needs to be created. See Table 30 for a description of CreateRegistration Method properties.
Table 30. CreateRegistration Method Properties
Properties
Description
Event Id
Session Id*
Prospect Id
Contact Id
Input Property - Registration or attendee Id of the parent event.
DummyId
Input Property - Dummy Registration Id.
Quote Item Id
Output Property - Quote Item Row Id.
Reg Id
Shopping Flag ('Y" or "")
UpdateRegistration Method
This method is called when a pending registration or attendee already exists. Completes the registration by calling other methods as necessary. See Table 31 for a description of UpdateRegistration Method properties.
Table 31. UpdateRegistration Method Properties
Properties
Description
Event Id
Session Id*
Prospect Id
Status
Input Property - Status for the registration.
Registration Date
Input Property - Date of the registration.
Contact Id
Reg Id*
Input Property
Quote Item Id
Reg Id
Output Property - Registration or attendee Id.
UpdateSpace Method
This method creates or updates a regn and updates event counts within a Lock to ensure transaction integrity. See Table 32 for a description of UpdateSpace Method properties.
Table 32. UpdateSpace Method Properties
Properties
Description
Session Id*
Prospect Id
Contact Id
Input Property - Registration/attendee Id of the parent event.
Action* (Mode of operation to be performed - create regn, update regn)
Input Property - Operation can be performed.
Increase count: Enroll an attendee
Drop from enroll: Drop an attendee (no functionality present for this currently)
Drop from waiting: Drop an WL attendee (no functionality present for this currently)
Drop from invited: Drop an invitee (no functionality present for this currently)
Waiting to enroll: Enroll an existing attendee (called from Update Regn)
Invitee to enroll: Enroll an invitee (called from Update Regn)
Reg Id
CheckQuote Method
This method determines whether the current user needs to be charged. See Table 33 for a description of CheckQuote Method properties.
Table 33. CheckQuote Method Properties
Properties
Description
Prospect Id
Contact Id
Reg Id*
AddToShoppingCart Method
This method invokes the shopping service to create a quote item. See Table 34 for a description of AddToShoppingCart Method properties.
Table 34. AddToShoppingCart Method Properties
Properties
Description
Prospect Id
Contact Id
Reg Id*
Input Property - Registration/attendee row Id.
Session Id*
Quote Id
Output Property - Quote Row Id. (Returns a quote Id if a new quote is created)
Quote Item Id
Output Property - Quote Item Row Id. (Returns a quote item Id if the quote item already exists in the same Web session.)
Siebel Events Management Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
