Siebel Field Service Guide > Cycle Counting and Replenishment > About the Replenishment Engine > Component Parameters for the Replenishment EngineComponent parameters for the engines in Siebel Field Service determine the behavior of each engine. Changing the values of these component parameters changes the default behavior of the engine.To implement changes to component parameters, restart the Field Service server. For more information about changing the values of component parameters, see Siebel System Administration Guide. Table 36 describes these component parameters for the Replenishment Engine. To avoid creating duplicate orders, the last 3 parameters in Table 36 specify the order item statuses, order statuses, and order types to find when searching for an existing order. CAUTION: The Order Status LOV must include Open in the Language-Independent Code field. Otherwise, the Replenishment Engine does not function. |
| Siebel Field Service Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
