Table 37. Parameters for the Replenishment Engine
InvokeMode |
SQL |
Specifies the WHERE clause to set up criteria and replenish the inventory locations that meet that criteria. |
Id |
Specifies the ID of the inventory location to replenish. The Replenishment engine replenishes that location. |
TEMP |
Places all the required parameters into a temporary table with a temporary Client Request ID and passes that ID to the server to retrieve the parameters from Temp Table. NOTE: Do not run component jobs in TEMP mode to call the Replenishment Engine. This mode is reserved for interactive engine jobs sent directly from a client application.
ClientId |
A row ID for retrieving parameters from the temp table |
This parameter is required when the InvokeMode parameter is TEMP. |
SourceType |
I (Inventory Location) V (Vendor) |
This parameter is required when the InvokeMode parameter is TEMP and defaults to I when the InvokeMode parameter is Id or SQL. |
DestId |
Destination Inventory ID |
This parameter is required when the InvokeMode parameter is Id. |
WhereClause |
SQL Where Clause |
Specifies the Business Component Search Spec mode. This parameter is required when the InvokeMode parameter is SQL. |
