Table 26. Component Parameters for the Fulfillment and Part Locator Engines
SysPref_DefaultFulfillInvLoc |
SFO |
Specifies the default inventory location to use as a source inventory location. The engines use this default value as the source inventory location if the user does not specify the source inventory location at run time. The value must be the row ID of the service inventory location. To see this ID, select an inventory location in any Service Inventory view, and then select About Record from the Help menu. |
SysPref_OrderItemStatusToBeFulfilled |
Open, New, Pending |
Specifies the valid values for the order item status. The values come from the Order Item Status LOV, and the individual values are LIVs. |
SysPref_OrderStatusToBeFulfilled |
Specifies the valid values for the order status. The values come from the Order Status LOV, and individual values are any of the LIVs. |
SysPref_OrderTypeToBeFulfilled |
Service Order, Internal Order, RMA Advance Exchange |
Specifies the valid values for the order type. The values come from the Order Type LOV, and individual values are any of the LIVs. |
SysPref_Fulfill-SearchAllSublevels |
TRUE |
Specifies whether child locations are searched. Values include:
- TRUE. Search the specified inventory location and all of its child inventory locations that sublevel relationships specify.
- FALSE. Search the specified inventory location and all of its fulfillment hierarchy locations, but not the child inventory locations that sublevel relationships specify.
SysPref_InventoryTypeForPT |
Warehouse |
Specifies the inventory location type for generating pick tickets. The values come from the Inventory Location Type LOV, and individual values are any of the LIVs. |
SysPref_AllocationRule |
1 |
Specifies the rules for substitution. Values include:
- 1. Always allocate a substitute before attempting to find the product at the next inventory location.
- 2. Allocate a substitute only if shipment from a single inventory location is allowed.
- 3. Never allocate a substitute if the exact product is found in another inventory location.
