Siebel Field Service Guide > Scheduling Using Oracle Real-Time Scheduler Version 1.0 > Process of Configuring Siebel Field Service Integration to Oracle Real-Time Scheduler 1.0 >
Setting Up and Configuring Workflow Processes and Policies
You must perform the procedures in this topic to be able to use real-time synchronization of address and employee data from the Siebel application to Oracle Real-Time Scheduler 1.0.
This topic contains the following related information:
This task is a step in Process of Configuring Siebel Field Service Integration to Oracle Real-Time Scheduler 1.0.
Activating Workflow Processes
Siebel administrators use the following procedure to activate workflow processes.
To activate workflow processes
  1. Navigate to the Administration - Business Processes screen, then the Workflow Deployment view.
  2. Query for *ORS*.
  3. Click Activate.
  4. Query for the Advanced Scheduler Skill Persistence Process, and click Activate for this workflow process.
Enabling Workflow Policies
Siebel administrators use the following procedure to enable workflow policies.
To enable workflow policies
  1. Navigate to the Administration - Business Processes screen, then the Workflow Policies view.
  2. Make sure that Expiration Date is properly set for all the workflow policies that are not in use.
  3. Query for *ORS*.
  4. Verify that the Expiration Date is not set for these workflow policies.
Shutting Down Workflow Monitor Agent
Siebel administrators use the following procedure to shut down Workflow Monitor Agent.
To shut down Workflow Monitor Agent
  1. Navigate to the Administration - Server Management screen, Servers, then Component Groups view.
  2. Query for Workflow Management.
  3. In the lower Components applet, query for Workflow Monitor Agent.
  4. Click Shut Down.
Dropping Database Triggers
Siebel administrators use the following procedure to drop database triggers.
To drop database triggers
  1. Navigate to the Administration - Server Management screen, then the Jobs view.
  2. Create a job for the Generate Triggers component.
  3. In the Job Parameters list, define the job parameter with the values in the following table.
    Name
    Value
    EXEC
    True
    Privileged User
    MS22116
    Privileged User Password
    (No example)
    Remove
    True
    Trigger File Name
    Droptrigger.sql
    NOTE:  The values for Privileged User and Privileged User Password must be the database user name and password that have the privileges to drop and generate triggers. The user name value in this table is an example.
  4. Start the job.
Generating Database Triggers
Siebel administrators use the following procedure to generate database triggers.
To generate database triggers
  3. In the Job Parameters list, define a job with the values in the following table.
    Name
    Value
    EXEC
    True
    Privileged User
    MS22116
    (no example)
    Trigger File Name
    Gentrigger.sql
  4. Start the job.
Configuring Workflow Monitor Agent
Siebel administrators use the following procedure to configure Workflow Monitor Agent.
To configure Workflow Monitor Agent
  1. Navigate to the Administration - Server Configuration screen, Enterprises, and then the Component Definitions view.
  2. Query for Workflow Monitor Agent, and perform the following steps:
    1. Change the Group Name to ORS Group.
    2. Change the Action Interval to 5.
  3. Click Advanced, and perform the following steps:
    1. Change the Sleep Time value to 5.
    2. Change the Default Task value to 1.
  4. Click Enable to change the status of the new component to Active.
  5. Restart the Siebel Server.
Siebel Field Service Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
