Siebel Forecasting Guide > Forecasting User Properties >
Forecast 2000 - Forecast Item Detail User Properties
Table 14 describes the user properties associated with the business component: Forecast 2000 - Forecast Item Detail.
Table 14. Forecast 2000 - Forecast Item Detail
User Property
Value
Description
Adjustment: Adjustable
Y
Used internally.
Adjustment: Adjustable Field n
Forecast Item Detail field
See Forecast Item: Adjustable Field n in Table 13.
Adjustment: Adjustment Allowed Field Name
Adjustment Allowed
Used internally.
See Forecast Item: Adjustment Allowed Field Name in Table 13.
Adjustment: Adjustment Context BC Name
Used internally.
See Forecast Item: Adjustment Context BC Name in Table 13.
Adjustment: Adjustment Context Id Field Name
Owner Forecast Id
Used internally.
See Forecast Item: Adjustment Context Id Field Name in Table 13.
Adjustment: Adjustment Flag Field Name
Adjusted Flag
Used internally.
See Forecast Item: Adjustment Flag Field Name in Table 13.
Adjustment: Adjustment For Id Field Name
Adjustment For Id
Used internally.
See Forecast Item: Adjustment For Id Field Name in Table 13.
Adjustment: Context BC Position Id Field Name
Owner Position Id
Used internally.
See Forecast Item: Context BC Position Id Field Name in Table 13.
On Field Update Set 1
"Amount Revenue", "Expected Value", "IIF([Win Probability] = 0", or,
[Amount Revenue] = 0, 0.0, [Win Probability]*[Amount Revenue]/100)"
Used internally.
Determines how the Expected Revenue is calculated when there are updates to the Revenue or Probability fields.
On Field Update Set 2
"Win Probability", "Expected Value", "IIF([Win Probability] = 0", or,
Used internally.
Revenue Field Map: Forecast Item Detail Field
Revenue Field
See Forecast Item: Revenue Field Map in Table 13.
Siebel Forecasting Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
