Table 15.	Forecast 2000 - Forecast Item Detail Flat
    | Adjustment: Adjustable | Y | Used internally.  See Forecast Item: Adjustable in Table 13. |
    | Adjustment: Adjustable Field n | Forecast Item Detail Flat field | See Forecast Item: Adjustable Field n in Table 13. |
    | Adjustment: Adjustment Allowed Field Name | Adjustment Allowed | Used internally. See Forecast Item: Adjustment Allowed Field Name in Table 13. |
    | Adjustment: Adjustment Context BC Name | Forecast 2000 - Forecast | Used internally. See Forecast Item: Adjustment Context BC Name in Table 13. |
    | Adjustment: Adjustment Context Id Field Name | Owner Forecast Id | Used internally. See Forecast Item: Adjustment Context Id Field Name in Table 13. |
    | Adjustment: Adjustment Flag Field Name | Adjusted Flag | Used internally. See Forecast Item: Adjustment Flag Field Name in Table 13. |
    | Adjustment: Adjustment For Id Field Name | Adjustment For Id | Used internally. See Forecast Item: Adjustment For Id Field Name in Table 13. |
    | Adjustment: Context BC Position Id Field Name | Owner Position Id | Used internally. See Forecast Item: Context BC Position Id Field Name in Table 13. |
    | Adjustment: Owner Position Id Field Name | Owner Position Id | Used internally. See Forecast Item: Owner Position Id in Table 13. |
    | Adjustment: Force Unadjust Parent BC | Forecast 2000 - Forecast Item | Used internally. When unadjusting this business component, the parent business component sometimes also needs to be unadjusted, for example, if it drives the visibility of this business component. |
    | Adjustment: Force Unadjust Parent BC Id Field Name | Forecast Item Id | Used internally. When unadjusting this business component, the field on this business component that links to the parent business component that it needs to unadjust. |
    | Aggregation Level Rollup | Y or N | Indicates whether or not rollup happens at each aggregation level. |
    | Aggregation Column Enabled | Aggregation Column Enabled | Indicates whether the column must be queried according to the aggregation hierarchy defined in the forecast series. |
    | On Field Update Invoke 1 | "Amount Revenue", "Forecast 2000 -- Forecast", "ForecastSetUpdateFlag" | Used internally.  If a subordinate updates their forecast by changing the Revenue amount, this property invokes a function to set the Refresh Alert field so that the manager will refresh the forecast. |
    | On Field Update Set 1 | "Amount Revenue", "Expected Value", "IIF([Win Probability] = 0",or,  [Amount Revenue] = 0, 0.0, [Win Probability]*[Amount Revenue]/100)" | Used internally. Determines how the Expected Revenue is calculated when there are updates to the Revenue or Probability fields. |
    | On Field Update Set 2 | "Win Probability", "Expected Value", "IIF([Win Probability] = 0", or,  [Amount Revenue] = 0, 0.0, [Win Probability]*[Amount Revenue]/100)" | Used internally. Determines how the Expected Revenue is calculated when there are updates to the Revenue or Probability fields. |
    | Revenue Associate List | Y | See Forecast Item: Revenue Associate List in Table 13. |
    | Revenue Field Map: Forecast Item Detail Field | Revenue Field | See Forecast Item: Revenue Field Map in Table 13. |
