A screen home page is a gateway to the common functions for that screen. Table 3-5 describes the main elements in screen home pages.
Table 3-5 Main Elements for Screen Home Pages
| Element | Description |
Frequently Viewed Screen name |
An area that contains a list of links to the lists of data with which you most frequently work. This list can be a combination of predefined queries and visibility filters. For more information, see "Setting Up View Links for Screen Home Pages". |
Recent Records |
Recent items area that contains a list of the last five records that you accessed (by drilling down on the record), created, or modified. This area allows you to return to a recent record with a single click. Recent records are stored in your user preferences. |
iHelp |
Task area that contains a list of links to the most important tasks for the screen. When you drill down on a task, iHelp is launched to guide you through the completion of the task. |
Search |
Query area where you can enter query criteria directly into the fields, and click Go to navigate directly to the list with your query results. |
Add |
Add area that you use to add new records. You complete the fields, and click Add & Go to add the record to the database and navigate directly to the form containing the new record you add. |
Note: Multi-Value Groups (MVGs) are not supported on Rapid Search or Rapid Add applets. |
