Icons appear at the top of lists and forms. Table 3-6 describes these icons. Your Siebel application might contain additional icons or other elements on each list and form.
Table 3-6 Common Icons in Lists and Forms
| Button | Description |
The Cogwheel icon accesses a menu of options that apply to the active form, list, explorer view, or selected record in a list. Using the options in the Cogwheel icon, you can perform actions such as copying, deleting, and advanced sorting. |
The plus (+) icon creates a new record. In a list, clicking this icon inserts a new row at the top of the list so you can create a new record. In a form, clicking this icon displays a form with empty fields that you can fill in to create a new record. |
The double plus (++) icon adds an existing record. |
The arrow-pointing-to-a-box icon saves the selected record. |
The arrow-pointing-up-and-back icon cancels modifications to the selected record. |
The Trash Can icon deletes the selected record. |
The Magnifying Glass icon starts a query in a form or list so that you can specify query criteria. For more information about querying, see Chapter 7, "Using Query to Locate Information." |
