Table 14-4 lists the keyboard shortcuts you can use to change the appearance of lists in the Siebel application.
Table 14-4 Layout Management Keyboard Shortcuts
Sort a single column.
ENTER
List column header
Open a dialog box to perform advanced sorting.
CTRL+SHIFT+O
List
Open a dialog box to select the displayed columns.
CTRL+SHIFT+K
CTRL+SHIFT+B
