Table 14-5 lists the keyboard shortcuts you can use when performing record management tasks in Siebel CRM.
Table 14-5 Record Management Keyboard Shortcuts
| Action | Keyboard Shortcut | Context |
Create a new record. |
CTRL+N (CTRL+ALT+N in Google Chrome) Note that if the list has a plus icon (+, for adding records) and a double plus icon (++, for creating new records), then CTRL+N opens an Add Record window from where you can do the following:
Note that CTRL+N is not available in Google Chrome, so use CTRL+ALT+N instead. |
List, form |
Create a new record using a Quick Fill template. |
CTRL+K |
Form |
Create a new record using the last used Quick Fill template. |
CTRL+J |
Form |
Apply a Quick Fill template to a record. |
CTRL+Q |
Form |
Copy a record. |
CTRL+B |
Record |
Save a record. |
CTRL+SHIFT+S CTRL+S (If you use this shortcut to save a record that has an invalid value in a field, then the Save As dialog box appears in error.) |
List, form |
Delete a record. |
CTRL+D Note that CTRL+D is not available in Mozilla Firefox, so it is recommended that you alter this shortcut accordingly. CTRL+ALT+D is the recommended option on Mozilla Firefox. |
Record |
Undo a record. |
ESC |
Record |
Select all records. |
CTRL+ALT+A (This applies when each record appears with a check box.) CTRL+A |
List |
