Table 14-8 lists the keyboard shortcuts you can use when performing field management tasks in Siebel CRM.
Table 14-8 Field Management Keyboard Shortcuts
| Action | Keyboard Shortcut | Context |
Open a selection dialog box for a field. Open the calendar control for a field. Open the calculator control for a field. |
F2 |
Field |
Close a selection dialog box for a field. |
CTRL+ALT+O |
Field |
Open a drop-down list for a field. |
F2 DOWN ARROW |
Field |
Drill down on a field. |
CTRL+SHIFT+SPACE |
Field |
