Siebel Hospitality Guide > Setting Up Charge Codes, Taxes, and Service Charges > Administering Tax Codes >
Creating a Tax Code
Use the following procedure to create tax codes.
This task is a step in Administering Tax Codes.
To create a tax code
  1. Navigate to the Tax Service Admin screen, then the Tax List view.
  2. In the Taxes list, create a new record, and complete the fields.
    Some of the fields are described in the following table.
    NOTE:  You can enter data in either the Amount or Percent field, but not both.
    Field
    Comments
    Name
    The name of the tax.
    Percent
    The tax defined as a percentage. The amount of tax charged is the percent value multiplied by the price for the line item.
    Amount
    Tax defined as a flat fee. The flat fee is a preset amount.
    Start Date
    The date the tax becomes active.
    End Date
    The date the tax becomes inactive.
    Currency
    The currency of the tax. Default value is the default currency of the application.
    City
    City in which the tax applies. A tax might apply in many different cities depending on the associated properties.
    State
    State in which the tax applies. This field is automatically populated when the City field is completed.
Siebel Hospitality Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
