Siebel Hospitality Guide > Setting Up Charge Codes, Taxes, and Service Charges > Administering Tax Codes > About Administering Tax CodesTaxes on a hospitality product can be a flat amount (for example, $5) or a percentage, and have defined effectivity dates. Taxes are defined on a global basis and are later associated with individual properties. Using charge codes, the calculation of taxes is based on the products associated with an order. When a flat tax is calculated during the Trial Check or Post Check process, the flat amount (for example, $2) is applied to each quantity of the product used. For more information about event checks, see Generating Event Checks. An occupancy tax is a flat tax assessed for room usage. For example, if a group uses Salon C, then a tax of $100 is levied regardless of the size of the group. Service charges and taxes are time-dependent; both have a start date and an end date. Service charge and tax date applicability is based on when the function with which the line item is associated occurs. Because multiple functions might be associated with each order and these calculations are done on an order basis, service charges and taxes might be different for different functions on one order. For example, a function might be held on 12/31/08 and another on 1/1/09, and a new set of taxes and service charges are effective on 01/01/09. If a function spans two days, then the tax applicability date is the first day. For more information about setting up service charges, see Administering Service Charges. Taxes must be defined before they can be associated with charge codes, service charges, and properties. There are two levels of visibility for taxes:
| Siebel Hospitality Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
