Siebel Hospitality Guide > Managing the Function Space Diary > Process of Configuring the Function Space Diary >
Configuring the Function Space Diary Icons
The diary uses several types of icon graphics. Icons identify different types of bookings and function details. Button icons identify navigation buttons. Hierarchy icons depict the hierarchical relationships among the function spaces. Siebel Hospitality provides a default set of icons for the diary. You can change the appearance of the diary icons by replacing the existing icon graphics with other graphics of your choice or design. This task is a step in Process of Configuring the Function Space Diary. To configure the Function Space Diary icons
- Navigate to the Administration - Application screen, then the System Preferences view.
- Create a new system preference record with field values as shown in the following table.
Sys Preference Name |
TNT CMT Configurable Icons |
None. |
Sys Preference Value |
Y |
A value of Y enables you to configure the icons. |
- Navigate to the following directory:
SWEAPP_ROOT\public\language code\images
In the directory path, language code represents the directory that is named with the three-letter code for the language of your Siebel application. For example, if the Siebel application is in English, then go to the ENU (English language) folder. Likewise, if the Siebel application is in Spanish, then go to the SPA (Spanish language) folder.
- Paste the new icon files into the \images folder to replace the default icons.
New icons must have the same file names and specifications as the default icons they replace. For more information about icon file names, functions, and specifications, see Icon Graphics and Files of the Function Space Diary.
- Refresh the Web Server.
For information about refreshing the Web Server, see the Siebel Installation Guide for the operating system you are using.
This topic covers the default icons, function icons, and button icons for the diary in Siebel Hospitality. Icons
All icon graphic files are BMP files. Pixel sizes are as follows, unless otherwise noted:
- 12 pixels wide
- 11 pixels high
The icons are listed in Table 92. Pictures, descriptions, and the types of bookings or function details that they indicate are shown in Icons in the Function Space Diary.
Table 92. Function Space Diary Picture Icons
24-hour hold |
ind_24hr_hold |
Standard |
Backup required |
ind_backup_req |
Standard |
Noise |
ind_noise |
Standard |
Host booking |
ind_host_booking |
Standard |
Affiliate booking |
ind_affiliates_booking |
Standard |
Related occurrence booking |
ind_recurring |
Standard |
Do not move |
ind_dont_move |
Standard |
Detail |
Ind_detail_marker |
Standard |
Suite |
ind_sleep |
Standard |
Holiday |
ind_holiday |
Standard |
Special event |
ind_special_events |
Standard |
Sell note |
ind_sell_note |
Standard |
Function schedule |
Ind_fnctn_schedule_marker |
Standard |
Red triangle |
ind_Red_Icon |
6 pixels wide 6 pixels high |
Hierarchy Icons
All hierarchy icon graphic files are BMP files. Pixel sizes are as follows:
- 18 pixels wide
- 18 pixels high
The hierarchy buttons depict the various relationships among the hierarchies of detailed and indivisible function spaces in the function space list. The hierarchy icons are shown and described in Table 93.
Table 93. Function Space Diary Hierarchy Icons
A vertical dotted line from top to bottom, intersecting a short, horizontal dotted line from the right |
hier_tee_ltr_d |
A blank space |
hier_space |
A minus sign in a box, with a horizontal dotted line intersecting the box at the right |
hier_collapse_ltr_d |
A plus sign in a box, with a horizontal dotted line intersecting the box at the right |
hier_expand_ltr_d |
A plus sign in a box, with a horizontal dotted line intersecting the box at the right and two vertical lines intersecting the box at the top and the bottom |
hier_exp_tee_ltr_d |
A plus sign in a box, with a horizontal dotted line intersecting the box at the right and a vertical line intersecting the box at the top |
hier_exp_elbow_ltr_d |
A short vertical dotted line from the top and a short horizontal line from the right, intersecting at the center |
hier_elbow_ltr_d |
A minus sign in a box, with a horizontal dotted line intersecting the box at the right and two vertical lines intersecting the box at the top and the bottom |
hier_coll_tee_ltr_d |
A minus sign in a box, with a horizontal dotted line intersecting the box at the right and a vertical line intersecting the box at the top |
hier_coll_elbow_ltr_d |
Button Icons
All button icon graphic files are BMP files. Pixel sizes are as follows:
- 16 pixels wide
- 16 pixels high
The button icons are shown and described in Table 94.
Table 94. Function Space Diary Button Icons
Black down-pointing double arrows on a gray background |
Diary_PageDown_Enabled |
Identifies an enabled Page Down button. |
Black up-pointing double arrows on a gray background |
Diary_PageUp_Enabled |
Identifies an enabled Page Up button. |
Gray down-pointing double arrows on a white background |
Diary_PageDown_Disabled |
Identifies a disabled Page Down button. |
Gray up-pointing double arrows on a white background |
Diary_PageUp_Disabled |
Identifies a disabled Page Up button. |
