Siebel Hospitality Guide > Setting Up Function Spaces, Sleeping Rooms, and Suites > Process of Setting Up Suites >
Setting Up Configured Specific Space Suites
The process of creating configured specific space suites is similar to the process for setting up configured specific spaces.
This task is a step in Process of Setting Up Suites.
To set up a configured specific space suite
  1. Navigate to the Property Administration screen, then the Properties view.
  2. In the Properties list, query for the required property.
  3. Click the link in the Property Name field, and then click the Specific Space view tab.
  4. In the Specific Space list, create a new record and select the Suite check box.
  5. Complete the other fields, as required.
    For more information about the fields on the Property Administration screen, Specific Space view, see Creating Indivisible Specific Spaces.
  6. Scroll down to the Components list and add a new record.
  7. In the Add Component dialog box, select an indivisible specific suite space and click OK.
  8. Repeat Step 6 and Step 7 to select additional components.
    For more information about adding components to a configured space, see Creating Configured Specific Spaces.
Siebel Hospitality Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
