Siebel Hospitality Guide > Getting Started with Siebel Hospitality > Disabling Date SynchronizationIn certain views that have more than one applet displaying a date range, the following behaviors occur:
To allow the flexibility to configure Siebel Hospitality to the business model of your company, you can disable these behaviors, either in all views at once or in selected views. This topic addresses the following subjects: This task is a step in Roadmap for Setting Up Siebel Hospitality. Related TopicsDisabling Date Synchronization in All ViewsBy default, date synchronization is enabled. The ACR575 - GRC system preference variable allows you to disable this functionality in all applicable views at once. The possible values of this user property are as follows: To disable date synchronization, follow this procedure. To disable date synchronization in all views For information about changing system preferences, see the chapter on ongoing administration tasks in Siebel Applications Administration Guide. Disabling Date Synchronization in Selected ViewsIf the ACR575 - GRC system preference is set to Y, then date synchronization is enabled in all applicable views. If you want date synchronization enabled in some but not all applicable views, then you can disable this functionality in one or more specific views. To disable date synchronization in selected views
For more information about changing the values of objects in Siebel Tools, see the chapter on working with objects in Using Siebel Tools. |
| Siebel Hospitality Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
